Can't go wrong with a 3 point blower. Simple as it getsI want to start using my B1700 for snow removal. Does anyone make a plow for it? I'd consider a snowblower as well. Also how do I hook them up because I don't have a spot for hooking up hydraulic hoses for an attachment.
They are a pain in the neck!Can't go wrong with a 3 point blower. Simple as it gets
Sent from my SAMSUNG-SGH-I337 using Tapatalk
You'll need to add a spool valve to control it, fairly easy to do.I will only have it front mounted. If I run a kubota snowblower, what hydraulic equipment will I need? I don't have a spot for the snowblowers hydraulic hoses to hook up and I don't have anything to control it.
Ok. I was unsure if that was the correct piece because every video I've seen they mount the spool valve on the rear. Where would I hook the spool valve up to?You'll need to add a spool valve to control it, fairly easy to do.![]()
Sent from my SAMSUNG-SGH-I337 using TapatalkThey are a pain in the neck!
