Harbor Freight Quick Hitch improvement
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
9
Columbia, CT
I love my HF quick hitch, but the hook binds a bit on my carryall. I found this replacement hook that moves the front of the hook farther back from the bolts. I'll report back after I try it out
Harbor Freight QH hook on top, replacement below
200mph
Mar 3, 2017
1,228
65
PA
Are you planing on sharing where you bought it and perhaps ordering info after you try it?:D
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
Hey Bucky, is that Madison, PA?
Have couple of friends up that way, they are vendors of mine and work with Exelon Power Generation.
JeepinMaxx
Mar 27, 2018
296
9
Columbia, CT
Finally had a chance to install the new hook today
Turns out the Harbor Freight Quick Hitch had slightly undersized bolt holes (probably made over-seas) , so I had to drill the holes out to standard 1/2"
Here's the stock HF hook above the new one - the extra 1/2" extension to the rear is noticeable
Finally I can hook up my carryall without the carryall top link mount binding on the HF top link hook mount and bolts! That extra 1/2" off-set of the new hook makes a huge difference!
JeepinMaxx
Mar 27, 2018
296
9
Columbia, CT
The HF and other imported QH's use metric bolts, they are (or where in your case LOL) 12mm. Yes they are made in China.
Yep - I checked, the original bolts were 12mm 8.8 (pretty much a ASME grade 5!) Kenny - I wish I knew you were making replacements for the HF QH! I love the bucket hooks I got from you earlier this year and recommend them to all my Kubota neighbors
Ike
Kubota L 3301, Farmall Cub. JD B. Ferguson TE 20
Jul 18, 2015
324
Mich
I welded a piece of 1 inch square stock on mine and drilled new holes for it. I had the same problem with binding and this fixed mine. I also drilled the holes out to 1/2 inch
Kennyd4110
Vendor Member
Sep 7, 2013
1,425
756
Westminster, MD
www.boltonhooks.com
Thanks JiM.
I have a few more tricks up my sleeve :wink:
