injector pump I.D
451johnny
61
Stroudsburg
I need to order the injector pump for my B7001 Kubota..I could bleed 2 injectors and 1 does not bleed so I was advised to change all 3 at the same time..now would that mean I should order the injector pump and does that bring along the 3 injectors with it ??? and any idea what it s cost ?? and do I have to remove the pump to get the part number on it..?? thanks in advance johnny
10,671
With the injection pump in, fuel being feed to it, and with all three injector lines off of the pump, set the throttle to high and crank it, if all three pump outputs put out the same height fountain you more than likely don't have a pump issue. ;)
manvstaco
B6000 with a B205 Front Dozer blade
Sep 24, 2018
9
Silverdale,Wa United States
There are several youtube videos in regards to testing your fuel injectors pump, pull them and rig up the high pressure lines and put a glass jar over each one when you crank over the engine you should see each one pop off and will give you an idea of their current spray pattern. GL
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,286
182
Coyote Flats,Texas
ok I think I can do that ..learning as I go...thanks johnny
Do you have good fuel flow from tank to injector pump??? Is fuel tank venting? How many hrs are showing on speed/hour meter? How long since fuel filter was changed?
