Field Tuff Fast Change Hitch System
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
Anyone else try these yet ?
Im a big fan of Pats and havent purchased yet and so I have founds these Field Tuffs cheaper than Pats and was wanting to hear reviews before buying them.
Also I once called Pats when I first received them and explained that I accidentally bent my spacer arm and they said no problem and mailed me a new one even though I admitted to damaging it myself. Im sure they would have question doing it again a second time, had I done it, but I was impressed with Pats customer service on that first and only phone call. Not much should go wrong with them but still.
One problem is that I cant find any customer contact info for Field Tuff or see who makes them ???
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
Wow these must be new.
I might have to be the Guinea pig. Lol
7,029
Not sure, but think I've seen these on the shelf at Tractor Supply.
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
Yes sir Im not surprised as Im seeing several retailers that are carrying them.
I just cant find any customer service contact info for the product itself.
Poohbear
Jul 6, 2018
527
192
Gilmer,Tx,United States
I bought the QH10 hitch and really like it. I look back on changing implements on the 2 old Fords I have owned and just shake my head at how HI-Tech I am now. I can't go back to shoveing & pulling trying to line up.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
how much loss of lift power does one get by lengthening their arms by using quick hitch like these?
wondering if it would be worth having a machine shop shortening them to get OEM length back into the arms after adding ones like PATS or any other type.
billrigsby
Mar 17, 2015
1,039
217
Florissant CO USA 8213'
www.facebook.com
mbu
260
United States
Do you know where to find more info on those?
You can purchase them here:
https://www.agristoreusa.com/collections/linkage-parts There are other places that sell them too.
These don't rely on shims or u-bolts to hold their positions and one doesn't have to alter any of their implement's drive shafts,etc for it match up to the tractor. They work even if the implement is not perfectly square or level with the tractor.
Here's a picture of them on my M7060. I machined new telescoping holders and welded them to those. This way, I still had the "captive" ball links that came with the tractor should I need them - but so far I haven't.
Here is another video showing these quick change hooks:
https://www.youtube.com/watch?v=4f3XP9_OZy0
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
http://www.orangetractortalks.com/forums/attachment.php?attachmentid=36651&d=1529469243[/img
[img]http://www.orangetractortalks.com/forums/attachment.php?attachmentid=36652&d=1529469301[/img
[url]https://www.youtube.com/watch?v=4f3XP9_OZy0[/url][/QUOTE]
Yeah, I would need Cat 1's. Otherwise i'd have to shim all my implements with Cat 2 bushings. I do not mind the idea of cutting and welding these on. I like the idea of nothing actually changing except i would have a helluva lot less hassle hooking up the heavy implements. Thank you for the info. I'll have to do some looking around to see about modding everything i have to Cat 2 lower pins.
I don't know if they are from Case IH as a factory thing but i know my neighbor runs them on both of his 200+ horsepower Case IH's, whatever category they use.
mbu
260
United States
...Yeah, I'll have to do some looking around to see about modding everything i have to Cat 2 lower pins. ...
You won't have to modify any of your implements! All you'll need to do is buy the balls that have a Cat 1 hole.
One thing nice about this system is that the hooks allow the balls to rotate in any direction - just like the captive balls do.
Anyway, I like this system as most of the equipment for my row crop tractors is Cat 3 and there is no way I can "manhandle" it to connect it. Using these quick hooks eliminates that problem entirely! In Europe this is the common hitch system and in the U.S. all the front 3PH come with these.
SRG
Jul 15, 2017
490
N. IL
Do you have to use the Cat 2-1 ball, or can you use the bushings sleeves? I'm not seeing the 2-1 ball on that site.
edritchey
2021 Ferris IS800Z - 2025 New Holland WM75
Jul 19, 2014
1,123
829
Wellsville, PA
I must be old fashion I still use the tried and true kick and curse method.
mbu
260
United States
I think they sell the 2-1 ball - you might shoot them an email and ask. I like the winged balls as they make connection of the implement even easier.
Note:
The lower link hooks were originally made by Walterscheid so if one does a google search using tractor lower link hooks one can find other companies knock offs.
SRG
Jul 15, 2017
490
N. IL
Yeah that's my go to, right now. Doesn't work to well on a 700lb tiller tho, unfortunately.
mbu, i appreciate all the info. I'll be doing more research on this conversion.
