Kubota cutting edge and aftermarket tooth bar
js5020
BX23S
Jun 27, 2018
75
PA
I just purchased my first Kubota last weekend, a BX23S. I would like to add the Kubota bolt on edge to minimize wear on the bucket. I would also like to have a tooth bar, are the aftermarket bars compatible with the bolt on wear edge?
2,864
If you get the toothbar ...you will not need the extra edge. If you wear the toothbar out......the tractor will be in the multi 1000's hours!:D
check this out:
http://bxpanded.com/piranha-toothbar
Tchess450
BX23S with 60inch deck. implements, blade, forks, spreader, and more.
Jun 18, 2018
45
Pa
I have the piranha toothbar on my Bx23s very happy with it. Easy to get on and off. They also sell a straight edge if you wanted both, and they mount the same way.
js5020
BX23S
Jun 27, 2018
75
PA
I've seen the bar from bxpanded but wonder if it's better than just a plain tooth bar for digging into a pile of hard rocky dirt? Then again I keep forgetting I have the hoe to do the actual digging and I should just use the loader for loading?
Sent from my LGL164VL using Tapatalk
7,029
Another Piranha vote - - never has been off in 5 years.
