Hello!
I was able to use a 5 year old post from orange tractor talks to locate the pesky hydraulic leak in my l200. My father in law and I have owned the tractor for a few years and use to mow, run a post hole digger, and disc a food plot. The 3pt hydraulic system has leaked/drifted down ever since we had the tractor and here recently I discovered the hydraulic fluid level was dropping while the gearbox fluid level was raising so I took the front cylinder cover off and extracted the hydraulic piston to find the hydraulic fluid was leaking past the o ring into the gearbox and ultimately leaking out the transmission bell housing weep hole.
I found a parts diagram at Coleman equipment and ordered what I thought were the correct o rings but I think these are for the l210 and not my l200. I've attached a photo of my hydraulic piston and the o ring on my l200.
Does anyone know where I can find this o ring?
Thank you!!!!
Joe Boone
Thank you!!!!
Joe Boone
