Hello, My name is Mike, I'm from Grafton Ohio. I just bought an L260 to replace my Ford 2N. I wanted a tractor with real hydraulics & better gearing to be able to do more with it.
I'm planning on replacing all the fluids & check the valve clearances before I do much with it. There are a couple of issues that I wanted to ask for advise with though.
1. The throttle linkages seem to be all messed up. The hand lever is disconnected, only the foot throttle works now. I've attached a picture of what it looks like now. Could someone post a picture of what it should look like so I can fix it?
2. The decompression cable is disconnected. When I put it back where it should be the cable sticks up pretty high. I'm not sure if that is correct or where it should be routed. Also, when the knob is pushed all the way in the lever will be pulled up about half way. I'm not sure if that is right?
3. The fitting the RPM cable attaches to is broke. I can't find it in the parts manual to buy a new one. Does anyone know if it is available & what the part number is? I've attached a pic of it too.
4. There's a momentary push button on the right side of the dash that the PO said was for the glow plugs. Is this correct? It seems like they are hooked to the start switch to me?
5. Can someone post a picture of the fuel filter & location? I think mine is missing & there are a couple of in-line fuel filters now. I want to make sure it is missing & then see about getting a new one.
6. I added a picture of the name plate. Is this a gray market tractor? I'm thinking no since the plate is in English, but I'm not sure.
I think that is all for now, but I'm sure I'll come up with more questions before long!
Thanks,
Mike
Thanks,
Mike
