L1801-temperature gauge install
fj40dave
Sep 24, 2009
425
257
Yelm, WA
I looked through some pic's I have of the L295 3cyl I rebuilt.....and figured I would consider adapting it to the drain on the block on the right side if I was looking at doing a temp gauge. Don't know if there would be a clearance issue on other components in that area for your tractor or not.
I wouldn't eliminate the drain per se, just put the gauge coupling in a "T" fashion between the block and the valve. Then again......would this get the water flow you might want to have for the accuracy of reading....hummmm...I bet ServiceDeptVic will know!:D
meanjean
Kubota MX4700
Aug 10, 2010
922
Hazelridge, Manitoba
Visited the local tractor shop.
The mechanic I chatted with said the petcock is not the best place for a temp. gauge.
Says it will always read cooler than near the top end of the engine, near the thermostat.
So....
Where is the next best spot (something off the block) for a temp gauge?
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
I bought a metal adapter piece that you cut a short portion from the center of the upper radiator hose and install it there. I found my adapter on Ebay.
This is on a B7100.
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
Here is a picture from ebay. You will need to measure the inside diameter of your radiator hose to know what size to order
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
There are literally millions of cars and trucks that have the temp sending unit threaded into the water jacket in side of the block, This is especially true of many of the inline 4 & 6 cyl machines, Considering that is more likely closer to the combustion chamber/process that is where the most heat is generated and stored, While the radiator hose sending unit is convenient it is isolated via rubber from the actual engine block and would most likely be a lower temperature reading in my opinion.
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
If you use one of the radiator hose adapters don't forget to connect a ground wire. They have a small tapped hole just for the ground.
cabu
Kuno B1-15 (B1502DT)
May 24, 2009
736
Germany, Oyten
... launch a recall ...
Before somebody is running in circles with the hands up in the air, I would like to mention to measure the temp-difference. The water is moving and the temperatur at the radiator should be everywhere nearly the same.
I am on a business-trip next to Macau, otherwise I would start Kuno to check it by myself. :)
carl
