B2620 question
boggie81
US
I have a B2620 tractor and a chance to buy a B2781 front blower with a B2761 subframe and a B2762 mid pto kit. Will it work?
Sent from my SM-G955U using Tapatalk
8,700
Need to know the serial # of both the tractor and the blower, there is a serial # break in that model.
boggie81
US
I do not have the serial # for the blower . I could post the tractor serial # later but not sure that will help without the blower #.
boggie81
US
I just bought a snow blower set up off of a B2620, it came with a B2733A hitch. They are expensive.
Do you happen to have any pictures of the mounting points on your tractor?
I assume the B2733A is what is needed for the B2620 tractor? I don't want to know what that set you back.
I hoping if I find some pics I may be able to modify the mount and get it to work.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,457
473
What model is that front blower and hitch made for?
Sorry I can't help you, I have a rear blower for my B2620.
Charlie5320
BX2670
Jan 8, 2018
114
9
Springfield, IL.
I don't have a B2620, I have a BX2670. The blower set up I bought was from a b2620, the hitch was too big for my tractor so I sold to a guy with a B2620. The back frame brackets bolt to the loader frame, same bolts. There are some utube videos showing how to attach the blower on your tractor.
boggie81
US
Not sure other than they said it was for a B series tractor.
I have a rear also, just thought about changing to a front mount.
boggie81
US
I'll have to check online for some videos.
8,700
All of the components that you list are for a B2710, B2910, B7800.
They are very very unlikely to just be bolt on, or slightly alter fitting parts.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,457
473
Just noticed I had it backwards boggie81......guess I should read better.
I didn't realize you had a BX tractor and the front hitch was off a B2620.
8,700
Think you got confused.
Boggie81 has a B2620
It's Charlie5320 that has a BX2670
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,457
473
That's normal. I'm always confused. Maybe I should START drinking? LOL.
That's what happens when you own trucks......you go brain dead.
boggie81
US
Thanks for the info. Modifying the brackets don't bother me if I knew the hitch it's self is the correct length and would mount on the front without much modification.
I guess I'll have to decide if I want to take the chance.
Charlie5320
BX2670
Jan 8, 2018
114
9
Springfield, IL.
The B2710 is a much longer tractor. The hitch is completely different, but you may be able to cut it down. Problem is going to be with the rear drive shaft. I finally found a pic of the hitch you are asking about. It is completely different where it mounts to the tractor, and it is much too long. Going to be a lot of fab work getting it set up for your tractor. Unless this setup is real cheap, you'd be better off getting the correct parts. I ran into the same problem and decided to sell what I had and buy the correct hitch for my tractor.
