M8200 A/C Blower Quit
Glovelis
M8200
Jun 30, 2014
26
Stonewall, Ok
Where should I begin troubleshooting my blower not working? It has a 4 position switch: off, 1, 2, 3 and the a/c button on the switch that when pushed activates the compressor. The a/c button still illuminates when pushed but no fan when I turn the switch.
8,731
As with any repair like this the WSM will be of great help to you as it has the Wiring diagram, and normally the troubleshooting directions. ;)
That system looks like it uses some complex controls, there is what they are calling an "amplifier" I believe its a control for the whole system.
Not something that I would try and mess with without the WSM for help.
What exact model M8200 do you have and I should be able to tell you the proper WSM to get.
8,731
Here is the right WSM
P/N 9Y021-18008
Sorry no cheap or free download available.
Glovelis
M8200
Jun 30, 2014
26
Stonewall, Ok
Glovelis,
Did you resolve this issue?
Not Yet! Yesterday I put 12v straight to fan blower and it worked. However, I did notice that my headlights will not come on and my blinkers aren't working either. I can hear the blinkers "clicking" but no lights. Now those two issues could be due to low voltage on my battery, I let it charge over night and will check when I get home.
Glovelis
M8200
Jun 30, 2014
26
Stonewall, Ok
The battery is 100% and the headlights and blinkers won’t work. Could the a/c blower and lights/blinkers not working be related?
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Yes, they're all electrical and don't work, so there is power or ground missing to all of them, pull and test each individual fuse, check harness connectors, perhaps a second fuse block on that model, ground connections at battery, fusible links at battery.
mbu
260
United States
Glovelis,
There are two locations for fuses - one in your cab and the other is at the front of the tractor near the radiator. I know earlier in this thread you posted that you checked the fuses but wanted to confirm that they were checked at both locations.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
5,257
1,043
As previously noted,
check the slow blow fuses near the battery, here is a manual for a model of your tractor, free download, covers M6800, M6800s, M82000, M9000, last part of electrical has cabin wiring diagrams.
https://www.manualslib.com/manual/1069659/Kubota-M6800s.html
NIW, different part number, 9Y011-18008, grab it for you cache if you don't have it.
This diagnostic chart is from the WSM 100td recommended
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Good onya Dave! I'll let you run with it from here, Thanks mate!
