chain storage tube
scotup362
L2501, loader, box scraper, flail mower. Yanmar Vio 35 mini-ex. 12' dumptrailer
12
Napa County, Ca
I recently got my first tractor and find my self looking for ways to store common items like chains and small hand tools.
Wait....what is that 4.25"x13.5" empty tube on the main frame of my LA525 loader?
olekid
B7510,loader, Curtis heated cab, loaded tires snowblower,grader blade,snow plow
Apr 9, 2013
92
Mount Uniacke, Nova Scotia
Great idea, you would think that Kubota would use some of these great ideas that come along and add them to the tractors. I suppose they would then charge an outrages price for the accessory.
Josef
2014 Kubota MX 5200 with 6 la1065 loader, sq172 Bush hog shredder, 6 ' Armstrong
Feb 25, 2016
282
victoria tx 77904
Yes, the torque tube make a great storage place-nice job!
A customer sent me this pics a few years ago, it's been on the website ever since:
What do you use to keep everything from falling out the other end of the tube. I suppose it would need to fit the inside diameter of the tube??? I believe we would have around 44" length and 4 and 5/16 inside diameter to work with.
Kennyd4110
Vendor Member
Sep 7, 2013
1,171
336
Westminster, MD
www.boltonhooks.com
I did not make it Josef, as I wrote "a customer sent me this picture..."
I assume he used some sort of cap on the pipe, a trip to the Home Cheapot plumbing isle and it could be figured easily.
2,172
I had the same problem with my vertical tubes - I did not want the mud and what not piling up inside the bottom of the tube against the steel floor plan.
I took a piece of sign aluminum and cut it in a circle and then used small screws to screw into the pipe - #6 with a square drive, counter sunk the alum plate so the screw would sit flat too.
I piece of treated wood cut on a band saw would do the same thing = could cut it to fit the ID of the tube too.;)
scotup362
12
Napa County, Ca
Josef,
the white tube is 4" thin wall drainage pipe. I used a 3" end cap and riveted it inside. The finished tube is 4" X 15" which holds a 12' length of 5/16 chain and two hooks.
Bruce
st8yd
2003 L3130 HST, LA513, Pats easy hitch
Dec 11, 2017
58
central FL
Thanks, but not my idea, I'm pretty sure I saw it here.
However the two small ones I did heat the pipe up and expand it to maximize the space, not much difference I imagine, but did it cuz I could suppose.
2,236
That drawer idea is great, I wish my FEL had cross tubes like that.:(
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
146
59
Central, ME,USA
This is a small tool box, but holds the tools to take off the 3 point arms to install the backhoe.
