BX80 series dealer installed cabs
SDT
multiple and various
Apr 15, 2018
3,085
927
SE, IN
If I may ask ,it cost you how much?
Today I saw a BX2680 with Curtis cab, MMM with bagger and FEL but without hoe on the truck at my dealer for delivery.
Salesman said it was $30K. The driver said it was LOUD inside.
MUCH too much for a BX.
SDT
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
Today I saw a BX2380 with Curtis cab, MMM with bagger and FEL but without hoe on the truck at my dealer for delivery.
SDT
My BX23S with cab was 30k with negative trade equity. No bagger.
Not too much when it's single digit temperatures out (at times -20 windchill) and you have 2-3 hours of plowing ahead of you. With the wind break provided, I can finish plowing without a break. I couldn't before.
It is loud inside with the PTO engaged. Noise canceling headphones are readily available.
Find one on a lot and try it out.
majorwager
MX5100 FEL ford 1620 FEL International 484 FEL Lull 844C
Now I don't feel bad about the cab I purchased from a cost perspective.
Mine is VERY warm in the summer, the solution is to just mow w/ the open station IH. If operating very early in morning at sunrise the ventilation system is adequate. But forget it when the temps rise into the 80's F. ++
However, winter plowing, long sleeve shirt, no hat or gloves, is pure bliss.
There are photos in the thread if there is interest. I still have an A/C option and purchased the unit, but lack incentive to install. Kinda enjoy open station in the summer.
Thread link in screenshot below.
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
It couldn’t be 30k. My BX23S, with SSQA, 60” mmm and 3pt hitch was 19,800. The cab is $4800.
jmf78
Nov 5, 2015
437
Edinboro, PA, USA
Mine was due to negative equity with the 2670 I'd traded in. Also new plow and quick hitch.
SDT
Apr 15, 2018
3,085
927
SE, IN
I well know the salesman.
He told me that the cab was around $6,000 installed and the bagger was over $2,000 installed.
I would have bought a 2650 with AC cab, etc.
SDT
SidecarFlip
Banned
548
It's cute, I'll give it that. Would fit in the front end loader bucket on either of my units. Seems pretty pricey for a tiny tractor.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
Hello jmf78. As for your refueling, how do you heat your home?
I have oil heat, so I just put a transfer pump right in my furnace oil tank.
Or if you have a pickup truck, just go get a 50 gallon transfer tank that goes in the bed with pump with hose. Those are the two easy options for no-mess fueling.
I don't play with cans anymore. And don't waste your money on those Flo and Go pump kits that go in gas cans. They don't last at all, they leak and in cold climates the hoses become unbendable, LOL.
78Vette
F2690
Mar 14, 2010
109
SW Ont. Canada
Why not some 3/4 inch (i think) clear hose and slide it to the can spout, giving you the extra room to empty the Jerry can/
jmf78
Nov 5, 2015
437
Edinboro, PA, USA
I heat my home with propane (primary) and wood (secondary or when we are home to enjoy it).
I have a pickup but it's a double cab Toyota Tacoma so...not sure if that would work so well for me.
I am also done with fuel cans. Well, for diesel anyway.
I ended up getting a 55 gallon drum and and a hand pump as a means to add fuel. Which worked out pretty well since my neighbor is able to bring me off-road diesel at cost from his employer.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
There you. That will work too, LOL.
Just put a good quality fuel conditioner in your barrel like Howes or whatever brand you like, since you may have fuel sitting for a while. 55 gallons will go a long way in these tractors.
FUSE
B3350-B2650-Z125s-KX008-Bobcat MT100-Case/Davis TF310
May 24, 2017
77
10
North Dakota
SDT
Agree with you there, if your gonna cab a BX you could just as well step into a 2650 with a cab, much nicer cab and tractor for not too much more money.
Cfrazer
BX2670-1,FEL, BX5450, BBox, GS1548, RB1560, QH05, AI2 Forks, SS Curtis Cab
Jan 22, 2018
86
North Rose, NY, USA
Agree completely with this, I have a 2670-1 with Curtis cab and can’t wait for snow again this year. I got the soft side version so I could save a little over a 1k dollars and the canvas works I’m warm and toasty in there.
Last time I checked the difference between a bx with cab and a b2650 with cab was around 5k, about 20 percent of purchase price on the BX, but its pretty easy to spend someone else’s money.
jmf78
Nov 5, 2015
437
Edinboro, PA, USA
I have a water filter on the pump and add power service to the fuel. No problems as of yet.
I don't disagree, and sometimes wish I had done so, but the BX is plenty of tractor for my 3.5 acres and what i use it for. It does everything that I need it to do.
rjcorazza
Mar 9, 2016
778
22
Hyattstown, MD
I have a water filter on the pump and add power service to the fuel. No problems as of yet. I don't disagree, and sometimes wish I had done so, but the BX is plenty of tractor for my 3.5 acres and what i use it for. It does everything that I need it to do.
Amazing what the BX tractors can do. Really all scuts.
A few years ago I abandoned open station tractors after years of freezing my butt off.
