L2850 Hydraulic issues
colej
L2850
Jun 27, 2016
paige
It was time to pull the filter and clean it and after replacing it there was no action on either the loader, 3point and the power steering very hard. So i pulled the filter again to check and the housing was still empty (after 15 minutes of running prior). I was thinking there was an air lock so i filled the sump of the filter and reinstalled and another 15 minutes and no action on the hydraulics.
It seems the hydraulic level is fine, if not a little overfull so there is plenty of fluid. It seems as if there is no suction from the pump up through the filter.
It was working prior to pulling the filter out to clean it. is there some relief valve or something that may be stuck open and not allowing the suction up from the transmission as that seems to be whats happening but I don't know the hydraulic system well enough. any suggestions greatly appreciated.
8,731
Most likely you have a leak in the suction line or fittings, as it has a 2 stage pump (PS on one stage and three point and loader on another) it's not very likely that the pump just went south, but it could be getting tired and not producing the needed suction.
This would be my #1: Any leak on the suction line or fittings will usually not present itself as a dripping leak, so inspect the suction line and connections for any wetness anywhere, and look for wear or any possible leaking point.
Also triple check that you have the right filter for it, and that the filter is not bad (seen a couple that were just made wrong and plugged up), also that the original gasket came off and is not causing it to leak there.
If the pump is on it's way out, you can crack the out line on the pump and sometimes get it to prime.
colej
L2850
Jun 27, 2016
paige
Thanks, I'll check those things out. I agree, very strange to just "die" like that after pulling and cleaning the filter. Yes, the filter is correct but now that you mention suction leaks i wonder if it's sucking in air around the o-ring for the filter sump as that hasn't been changed in a very long time.
cheers
Jaketheone46
Kubota L2850
Aug 28, 2023
21
KY
cheers
I have a 1988 Kubota l2850 it’s the regular standard gear shift and not the GST model. I was trying to look up hydraulic filter info and from all I can tell my tractor just has 1 spin on style hydraulic filter that looks like a regular filter so when I found this thread and you said you pulled your hydraulic filter to clean it I don’t understand?? Is there some type of filter on my tractor that I’m supposed to clean?? I’ve checked around and from what I’ve read mine does not have one of those long screen style hydraulic filters and only has a spin on standard metal can type of filter.
so now I see your thread here and don’t understand what filter there is on the L2850 that you clean??
Just planning to change my spin on filter and if there’s another filter I am unaware of I’d like to replace it as well.
if anyone can help me understand please let me know. Thanks Jake
2,043
@Jaketheone46
That member has not been on the forum since 2017 so doubtful they will respond.
But there are two types of filters on the L2850 depending on when the tractor was built. Apparently there was a canister filter that was but in later production the canister filter was used.
I found this by looking at the illustrated parts list from Kubota (see below). I think the canister filter was a screen that could be cleaned and reused.
