Why 2 Fuel Filters?
Sailboater410
BX24
Apr 12, 2017
Duvall, WA
The BX tractor series (I have the BX24) has 2 fuel filters in series. After over 500 hours of operation I recently discovered the second one is sandwiched between the floor and my bottom protective shield (similar to Brotek). Can anyone speculate about why there are 2 filters in series? I ask because of the access issue for the buried filter, I'd like to eliminate it. To me, only 1 filter should be required since (with 2 in series) the first one is catching 99% of the crud and the second has very little benefit.
Has anyone looked at this?
Any ideas why there are 2 filters in series?
Anyone see any harm in eliminating the buried filter and going with a single filter accessible in the engine compartment?
Thanks for your feedback!
Ron
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,189
169
Hardisty, Alberta
Ron
The first filter is also protecting your electric fuel pump! I guess you could get away without the second one but why do the M6 tractors have 5 fuel filters? In my opinion the better you filter that fuel the happier your tractor ( and you) will be!
6,624
I've got a 1966 Case 730 tractor. It has 3 fuel filters in series, a primary, secondary and a final. All are big size filters. They wanted the fuel to be clean! Still starts easily and runs like a top.
Filters are those little items that save you big-time expense. Be sure to use quality filters, and fluids, to preserve your machines usefulness.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
The second one is there to protect the injectors in case the fuel pump comes apart. If you take the old pump and tear it apart, it really is s simple thing that could disintegrate. It does do a supplemental bit of filtering also. I'm talking abut the filter just before fuel gets to the injectors. If you have not been changing the first filter between the fuel tank and the fuel pump, it is amazing your tractor still runs. That does the major filtering of the fuel. Do a Google search for BX fuel filter replacement which shows how to install a much larger first filter. I had some crud in my fuel and had to do something about frequent plugged first filter.
Sailboater410
BX24
Apr 12, 2017
Duvall, WA
Good points, thank you. From the Kubota online diagram I missed the electric fuel pump between the two filters, and point taken that redundancy is a good thing. Once I get my bottom plate off and scope out the real estate I'll see if I can shift it somewhere else for better accessibility.
CountryBumkin
BX2370 w/LA243, Bucket, Grapple, QA Pallet Forks, 60" MMM, rear blade & rake
Sep 27, 2015
568
Central FL
Sailboater410
BX24
Apr 12, 2017
Duvall, WA
Cerlawson, that's how I discovered the 2nd filter, my tractor would run terribly after about an hour of use, RPMs would drop, then come back and be fine for awhile.... very intermittent. Been putting up with this for years. I'd change the visible filter and it seemed to help a little, but the problem didn't go away entirely. Two days ago it became completely unusable and I limped back to the shed. After researching online I heard about the 2nd filter, crud in the tank, etc. so here I am. I did find a video online that I'll watch at lunch today regarding a filter upgrade, good tip, thank you! Relocation would be nice so I can change it more regularly and easily as well.
Cheers!
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
My zd326 had the same inline setup that the bx tractors have. In addition to being a pain to replace, they aren't that great of a filter micron wise. I replaced the first filter with a large Cat spin on filter rated at 2 microns. Bolted to the frame, it is easy to replace.
