Well, following on from the posted issue of black smoke due to the air filter being blocked with snow I thought I would have a look at a mod.
I have not altered or damaged any of the existing items and will reinstall the standard intake come grass cutting season.
As the problem stemmed from light blown snow entering the intake at the front and causing the blockage. So I though that an intake close to the exhaust and pointed slightly back might be a simple fix.
I used a standard 1.5 inch 90 plumbing bend with a male/ female end, I used a Dremel with a sanding drum to increase the inside diameter to fit snugly over the air cleaner spigot, added a short section of 2 inch thin walled tube , cut a slight angle to allow for clearance to the exhaust, it is about 1.25 inches from the exhaust and covered the end with aluminium tape to add a small level or heat protection.
I cannot forsee any issue with heat and as the air temp is generally cold when in use. There should be no issue with combustion intake temp.
some images. Oh, cost $1.49 slightly less than a Kubota part I am sure.
