Temp and pressure gauge??
melvinhatcher
L3301HST, LA525FEL, 66" QA BUCKET, L8455CRUISE CONTROL KIT, WR LONG 3RD FUNCITIO
Feb 16, 2016
192
Edgewood Maryland
I have a 2016 L3301 with a LA525 front end loader. Has anyone installed a pressure and temperature gauges that can be read from the operator's seat for the LA525 loader? :)
8,531
The temp and pressure gauge wouldn't do a whole lot for you on a day to day setup.
Why do you think you need those?
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
Probably not, but I am sort of a gadget guy, and I would like to know the temperature of my HST oil and how much pressure is on the system while working with the loader. Just a me thang. :p
Thanks for your reply. OBTW, I have to run, mama is holing it's bedtime.
Tooljunkie
May 13, 2014
4,150
I recall many yeas ago a car came in that had every guage you could imagine. From an aircraft. Anything that could operate in a car was installed in the dash.
I could see a pressure guage on a boom lift cylinder, if i needed to know rough weight of a load in bucket.
MadMax31
BX23S, 60" MMM
Nov 5, 2014
763
New York
You could run pilot tubing from HST for a pressure gauge, but honestly why would you want upwards of 2300 psi right in eye-sight.
I have toiled with the idea of a temp gauge for my HST. After a few hours of bush hogging the base of the seat is hoooot. There is an oil cooler with radiator, and as long as I keep those two clean Im not worried.
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
Honestly the HST fluid and pressure is already right in eye-sight via the hoses and connector at the third function valve and Loader control stick. :p
MadMax31
BX23S, 60" MMM
Nov 5, 2014
763
New York
All components rated for far higher pressure and tested by Kubota not to fail and cause lawsuits. Your absolutely free to modify your machine as you see fit, but for me, Ill pass.
Im in the HVAC world, refrigerants are far lower pressure, and almost every remote gauge Ive seen, mounted by factory or Tech, has leaked or the tubing cracked from vibrations.
Kenny D sells a nice test gauge kit. You could check pressures with it quite often.
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
Hi guys, its just a me thang, I have a pressure gauge installed on my wood splitter, works nice, and don't seems dangerous to me.
My thought was to do the same for the tractor, since the connectors, are in plane view on the tractor. The fluid pressure is there right in "eye" view of the operator, on my log splitter, and would be on my tractor. in my opinion it is just how it is installed.:rolleyes:
8,531
Pressure gauge need to be 3000psi rated.
Temp gauge needs to be 500f rated.
Pressure gauge would be fine installed in the pressure line going to the loader valve.
Temp gauge sending unit needs to be installed into the side of the rear end about mid way up the case but under the fluid level.
