2012 M7040 manuals and I'm confused
wingmaster
England
Hi, I have recently bought a 2012 M7040 with cab and FEL
Can somebody please send me a link where i can find the manual for a 2012 M7040 ? apparently there are separate manuals for the loader, shuttle shift and the tractor itself.
I'd like to read up on the use of the shuttle shift as i'm confused as to when to and when to not use the clutch.
Thanks
8,785
I sent you an Email with both the WSM and the OPS manual downloads. ;)
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,244
159
Coyote Flats,Texas
Ditto no need to depress clutch pedal to change from forward to reverse or vice versa. Shuttle should be shifted a lower engine rpm's & slower ground speeds.
FYI depressing clutch pedal opens a hyd valve but doesn't have any effect on traction clutch(damper) disk as it stays engaged 24/7.
