Post hole digger
danrn2500
B2920, belly mower, loader, PHD, 3 point box
Jan 16, 2017
Colorado Springs, CO.
Just purchased my first tractor with a 12 inch PHD. Gave it a try and it dug about a foot and wouldn't go much further. Ground may have been kind of hard, but would like to know if I could do anything to help it dig a little better.
Thanks
Trex1200r
B2301/54"MMM/QA FEL
Dec 22, 2015
Elizabeth, CO
Letting water sit in the hole really helps. In hard clay soil, the water might have to sit overnight.
Another option, but be careful not to let the big auger get too deep too fast or it will get stuck is to use a smaller auger bit to drill a pilot hole first.
The thing to remember about tractors is they don't apply any down force on the auger other than the weight of the implement itself, so they don't work nearly as good as the skid steer setups.
MtnViewRanch
868
306
Lakeside Ca.
Drilling a pilot hole is not a good idea. The bigger bit will not just follow the smaller hole down. This is not wood or metal, different types of bits.
If the OP is like me and doesn't have time to fool with getting holes dug having to wait for water to soften the ground, he can get a hydraulic down pressure kit for his PHD. This almost always takes care of the slow digging problems found with very hard ground.
gpurp
M5140
Nov 9, 2016
I'm actually considering a Landpride PHD with the down force kit. Specs claim it will add up to 500lbs extra down pressure. I think it's only available on certain models though.
Sent from my SM-G925V using Tapatalk
MtnViewRanch
868
306
Lakeside Ca.
I'm relatively certain that the down pressure kits are available for every 3pt PHD that they have. What I do know for sure is that on my PD35 (biggest PTO unit they have), the difference is like day and night. I went from not being able to drill hole even in a days time soaking with water to never taking more than 2 minutes in dry hard (DG) even with a 24"hole 4' deep. :cool:
Note that the PD35 has a lower gear ratio which adds a lot of torque.
Caboose
B2650HST
Aug 16, 2016
80
Washington State
MVR, which tractor are you running and with what PTO HP? I'm looking at buying a PHD as well but only have 19.5 PTO HP. I was considering the PD15 from Land Pride. I wonder if the down-pressure kit would work with that and what extra I would need on my tractor to make that work.
Dean
MtnViewRanch
868
306
Lakeside Ca.
Dean
That particular tractor is a 75HP machine and has 65PTO HP. You need a rear remote and a separate direct return to tank connection point.
The down pressure cylinders are single acting with a pressure relief valve. This pressure relief valve allows the 3pt to override and collapse the cylinder when the hitch is raised, thus the separate direct return to tank line.
I am a weekender. So when I need to do something, I need to do it and get it done, not wait for days to let water soak in.
This prompted me to get the down pressure kit. I have about $3600 in my whole setup, but I have 5 different good (not economy)bits at 6",9",12" 16" & 24". The PD35 is substantially more $$ than the PD25.
It comes down to what you need, what you decide you can get by with and ultimately what you are willing to spend.
