Snow blade
melvinhatcher
L3301HST, LA525FEL, 66" QA BUCKET, L8455CRUISE CONTROL KIT, WR LONG 3RD FUNCITIO
Feb 16, 2016
192
Edgewood Maryland
My snow blade angles too fast, I have to really lower the rpms to slow the blade down while angling from one side to the other. Is there a way to lower the pressure to slow this thing down without lowering the rpms? :eek:
5,345
Take a line off to the ram and insert a washer with a pin hole center, really that's all it takes, it slows the flow down. ;)
5,345
I've used as small as a 32nd, but a 1/16 should work well! ;)
You can always make it bigger if it's too slow. ;)
And you do only need to do one line as it will restrict flow in both directions.
Tooljunkie
May 13, 2014
4,150
Start with 1/16" and drill up from there. I have a hydraulic landscape rake with flow restrictors and theres just pinholes. Thinking this is what you need.
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
Hello guys, my problem is solved. I ordered The Thumb to install on loader bucket and it came with two flow restrictors. I installed the two restrictors to the hose ends of the third function valve, therefore any attachment I install to the tractor will receive a reduced hydraulic flow rate. So far, the snow blade is perfect at any engine rpm
