Battery tender port
Itsals1
12
Eau Claire,WI,USA
I've been looking for a dash port for my battery tender. I've seen some mounted on bx's! I really dislike having to open the hood to plug in the tender, just want a neat clean factory look. Anyone have suggestions on where to find one of these? No one locally seems to have one. Thanks in advance!
4,058
I dont know for sure but I would guess you could mount a cigette lighter socket and wire it through a fuse to the battery and then plug into that
CountryBumkin
BX2370 w/LA243, Bucket, Grapple, QA Pallet Forks, 60" MMM, rear blade & rake
Sep 27, 2015
568
Central FL
The battery tender I use on my truck comes with a 8" pigtail lead to plug into (the pigtail plugs into hardwired connection or alligator clips). this makes it easy to install so that the lead is accessible without opening the hood (or removing battery access panel).
The 12V power port would work as a charging port if it is hot with the key off.
CaveCreekRay
Jul 11, 2014
2,631
105
Cave Creek, AZ
Itsals1
12
Eau Claire,WI,USA
Wow!!
That's exactly what I've been looking for. I have a 3 of the expensive ($20.00) Harbor Freight tenders (5 stars my opinion) and they could plug directly into either one of these above. You folks are fantastic!! Thanks for the help.
trapperdrew
2017 BX23S TLB
Dec 16, 2015
116
I used the luggage one for a motor bike.
The 2nd link from above.
It has worked quite well for me.
3,095
On my b7100, I used a polarized pigtail zip-tied to the steering column. (see pic, arrow)
On my Rhino, I had already wired the cig lighter socket for a constant 12V 30a, (even with key off) so it was logical to put a cig lighter plug on the battery tender.
NEPA Guy
B2650HSDC, Spacers, FEL, BH, Snowblower, Snowplow, PBar, Forks
Nov 28, 2015
424
Pennsyltucky
I discovered the NOCO Genius chargers on this forum. I now have two and love them.
I just bought this nifty dash jack for my ute. Haven't installed it yet but I really like the NOCO quality.
https://www.amazon.com/NOCO-GC016-Dashmount-Battery-Indicator/dp/B009MI9L6U/ref=sr_1_1?ie=UTF8&qid=1468360444&sr=8-1&keywords=NOCO+dash+plug
Ray
I love the NOCO brand. I have two chargers. I was thinking about picking up one of these once I install my block heater. I had a hard time finding a suitable cover for the plug that hangs out.
https://www.amazon.com/gp/product/B009ANV81S/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
CountryBumkin
Sep 27, 2015
568
Central FL
Just be sure that whatever battery charger brand you buy, has a "maintenance mode" which prevents overcharging.
You don't what a standard type battery charger that just charges at 2A (or whatever) continuously as that could overcharge your battery.
Generally, the changers that are called "smart chargers" or "battery tender" have this maintenance mode.
Delmar
G1900 / Kubota BX
Sep 24, 2015
180
Bluegrass State
I did something very similar to trapperdrew on my BX.
Drill a hole (making sure you've got sufficient room behind it) and mount the receptacle. Easy. There's several brands/options. Got mine on Amazon for around $20.
FWIW, I also installed a very similar AC port for my block heater. Since I use it so rarely I just mounted it behind the radiator screen.
