clicking noise from front wheel bx2350
Bunnyfarm1
bx2350
May 10, 2016
covington,tn
My tractor is making a strange clicking or popping noise from the front right wheel. It does it in either 4wld or 2wld. It only happens sporatically. There will be a few clicks then its quiet for a while. When going from forward to reverse it will click each time I change directions. Any help is appreciated I'm hoping I can fix this myself.
Bunnyfarm1
bx2350
May 10, 2016
covington,tn
Tightened all the lugs. Still popping. It may just be my wishful thinking but the popping doesn't seem as often now.
Sent from my SAMSUNG-SM-N910A using Tapatalk
1970cs
1,124
Grand Ledge
The final drive on that side sounds like it's have a bearing issue and or dropping teeth on one of the bevel gears. You are going to have to tear it down and inspect.
Pat
Bunnyfarm1
bx2350
May 10, 2016
covington,tn
That doesn't sound fun. Where can I find a schematic of how everything goes together or repair book
Françoys Pharand
BX 2350
Oct 22, 2021
St-Jean, Qué.
I have the same problem with the left front wheel.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
If the wheel nuts were loose, take a close look at the wheels and check for hairline cracks. You can also swap L to R and see if the noise follows the wheel. Look at the welds too. If not, you're into internally lubricated parts.
B737
LX3310
Jun 9, 2019
2,022
2,205
check / tighten the bolts on the steering rack, they commonly come loose.
