Kubota BX2660
ozzie
FEL
Nov 8, 2010
15
Australia
Hi All. Just some information on the transmission dipstick of the BX2660.
The markings on the dipstick show 5 crosses from the bottom up then 2 dimples half inch apart. The other side also has 2 dimples, but further up the dipstick. The manual is not very clear at where the oil level should be. Would anyone know where the oil level should be? Now, it is at the top of the crosses.
Thank you.
ozzie.
TripleR
Sep 16, 2011
1,911
SE Missouri
If the oil level is not above the cross hatch, you should be OK, I usually have mine just below the top, but I'm pretty comfortable if it is where you indicate.
2,835
Thank you.
ozzie.
As long as you are in the cross-hatched area, you are in good shape, better to be a little low as to a little too high.
