b7100 cluch inspection
Dennis
79
Queensland Australia
No way to visually inspect it. You need to determine if the clutch needs repair/replacement by the symptoms your tractor is displaying. If you need any help let me know as I have just split my b7100 ( with a lot of help from the guys on this forum) and replaced the clutch but also found a lot of other worn parts.
stylo
24
new egypt, nj
thanks dennis, i was just hopein while i have the thing all stripped down i could check it before i put it back togrther. it was only sitting for a year but it only has 300 hrs on it, so i dont know. just dont want to have to rip it back down after i get it back together.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
is there any easy way to visualy check the cluch to see if it needs replacement or how much its worn?
My WSM says to measure depth from the disk surface to the top of the rivit heads and replace it if the distance is less than 0.1mm ( 0.004 inch)
Dennis
79
Stylo,
you saythe tractor is stripped down; does that mean you have split it at the belhousing.
If that's the case there are a number of things you can check out for excessive wear while you are in there
maximus
B7000
Aug 10, 2010
UK
Stylo,
Hi Dennis,
What other things did you find were worn out Dennis?
Thanks
Dennis
79
Pilot Bearing, Pilot bearing seal, Presssure plate levers, Thrust bearing, Clutch fork, Clutch bearing holder seals.
The discs themselves were not too bad but, with advice, I replaced both pressure and friction plates and machined the flywheel.
While you are at it, check the ball coupling at the transmission end of the drive shaft.
Rickcas gave me the good advice on this (see his posts) Mine was really loose and worn.
See posts on splitting tractor at this site
stylo
24
new egypt, nj
sorry it took so long to get back, but i have the tractor stripped down prety far as i am respraying everything but i really dont wana split the thing.
