Rear Tire Chains on L-48
skles
L-48 B3200
Jan 27, 2016
Mishicot Wi. USA
I have a newer L-48 ~2008 ....I live in Wisconsin and we got snow. I have trouble on any slight grade ...turf tires.....there does not seem to be any room for rear tire chains....but every one will sell you some. Can it be done ??
8,764
Get wheel spacers, look on EBay. ;)
L48 with turf tires?????
Post a picture of it!
What size tires are they???
Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
Feb 16, 2015
1,022
11
Lovells, Mi
Turf tires give good snow traction, what are you doing and how big is the implement when you are having trouble?
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
11
East Hampton, CT
Agreed, never seen an L48 with turfs! Yes you will need spacers as Wolfman states or you can flip the rims to the outside of the hubs if you have a 2 piece rim assembly. When you flip the rims out you will swap left to right keeping tires pointed in the right direction and put the rims on from the outside rather than inside.
Look for Canadian logger chains http://www.canadianchainsusa.com/Inventory/Category/1326/
The studded ones are SERIOUS and will work great in snow, ice, whatever.
Billdog350
Jan 6, 2014
468
11
East Hampton, CT
You should be able to swap those tires left to right and put them on the outside of the inner hub and gain more width.....
8,764
Billdog,
You should note that they are 2 piece rims (center is removable) and look in second pic, they are already dished in and on the inside of the loops on the outer rim.
So no way to make it any wider without adding axle spacers. ;)
Billdog350
Jan 6, 2014
468
11
East Hampton, CT
Wolfman, it seems you're right! I know the R4's have decent clearance when the rims are flipped to the outside so I was assuming that those on the L48 above still needed to be flipped to the "deeper" side of the rim, but alas it appears spacers are needed!
