bx2360 Quits pushing under a load
gopherted
kubota 2360
Jan 25, 2016
West Virginia
I was plowing snow and when I would get a large amount of snow in front of the bucket it would quit pushing and seam like an axle was striped and when I would let off the tram peddle a little bit it would start going again, as long as there no heavy load in front of the bucket it trams fine,what could be going bad.
uglyboy
TG1860G
Mar 8, 2013
87
St. George, Ontario
pushing down on the hydro pedal on the BX results in essentially a higher gear ratio, but less power, not more... unlike a car gas pedal.
I don't know what's slipping... maybe tires spinning, but with your tractor, when the load gets heavier, you need to back off on the pedal, or increase throttle, to get more power.
Pete
gopherted
kubota 2360
Jan 25, 2016
West Virginia
Thanks Pete but the problem is that the tires used to spin when under a load and now it stops in it"s tracks and shudders the whole machine.
bcp
BX2360
Apr 20, 2011
644
79
SW WA
Mine does that if I accidentally have it in Rabbit instead of Turtle.
Bruce
2,781
Bruce
Bruce has the right answer - high range is almost useless when it comes to power - low range is slow, but has almost unlimited power, but I have stalled my machine in low range by working it too hard.;)
3,932
Maybe check the tire pressure too,, they have been known to loose pressure and the rim slip in the tire,,, yes it do happen!!!
