Control Valve Lock lever
Biotex
B7800 HST
Nov 11, 2015
Alpine, TX
What is it, how does it work? I can't get the lever to move and I don't have the operator manual. I'd like to know the proper way to use it. LA402 on a B7800
Tractor is my first!
BravoXray
BX-25D, Ford 9N, Bobcat 825. Too many implements to list
Feb 6, 2014
190
Lake Winola,PA.
My tractor is different than yours, on mine you just flip the lock, less than ninety degrees and it will unlock. The idea is that you can lock the lever so that you don't bump it, like when your climbing off the tractor with a big coat on in a blowing blizzard, at midnight, while your cell phone is ringing and a black cat runs in front of you. Now your caught on the loader lever, and the loader is lifting up fast, and its full of gravel and ice pellets, and they fall all over your nice shiny hood. I just climb on and off the other side as a general rule. If I have someone new on the tractor, I might lift the loader up a little, and then lock it, so that they can't use the loader when they thought it was the throttle. It doesn't lock your loader arms up, you can't use it to lock them safe while you get under them, because a line could burst and the arms would come down really fast!
I hope you enjoy your new tractor, everyone should have at least one!
Jerry
Biotex
B7800 HST
Nov 11, 2015
Alpine, TX
Thanks for the detailed explanation Jerry. Any idea why the lever doesn't move? Seems to be frozen in the unlocked position. I haven't "leaned" on it yet. Wanted to know what it did first.
BravoXray
Feb 6, 2014
190
Lake Winola,PA.
I don't have a good guess, but I would suggest that you post a photo, there are a bunch of folks on here who might take a go at it. Messick's might also have a parts diagram that might help. If I think of anything in the meantime I'll jump in.
If the tractor has sat outside a lot maybe something simple like PB Blaster might loosen it up. I wouldn't lean to hard, that tends to get expensive too fast for my blood!
Jerry
R.Ducky
Athens, TX
I think it is a horrible design. Mine has not worked in 4 years since it was new. I have had it in the shop several times. Now today, the lever will not go forward or back. 3point works fine, FEL curls fine but will not lift or lower.
