gr2120 deck lift lever replacement
tommyb
22
Wallingford, CT.
Hi all,
So, went to replace the hydro deck lift lever today. (Bought the mower used, the lever's bent so it hits the deck engage lever).
It's keyed and could be easily replaced if the fender had an opening to do so, but, looks like you have to remove the whole fender (seat and all) to move the lever back far enough to match the lever rod's keyway to slide it out. Am I missing something???
Help and guidance is much appreciated.
Thanks!
tommy
tommyb
22
Wallingford, CT.
Hi all,
Thanks!
tommy
Update:
Picked up the WSM for the GR2120 from the dealer.
Started the project to replace the hyd lever today.
Have the fender all lose and ready to remove except for 2 seemingly simple things:
1. The mower height setting knob, this appears to be pressed on but does not budge with some pretty hard pull force, I don't want to break it. Any ideas how to do it? :confused:
2. The PTO knob/handle, is it glued on? Any hints how to remove it? :confused:
Any trade secrets will be kept on the down low...lol
So far I have to order 15 new plastic fasteners that hold down the floor mat, I see another Messicks order in my near future.
I'll try and post some pics soon.
TIA!
OBKubota
2014Gr2120,Gr2728Snowblower,Gck5GrassCatcher,agri-FabSpreader
Oct 21, 2014
205
Ontario
On mine it looks like the hydraulic up and down lever would drop right down thru the console once loosened.
OBKubota
Oct 21, 2014
205
Ontario
And the yellow pto mower engage lever would come up thru console once bolts were removed. It would be nice to see a pic of the bent lever.
1,042
Try to apply heat from a blow dryer or heat gun (no flame) to plastic knob then try to pull them off. Good luck!
tommyb
22
Wallingford, CT.
Thanks for the suggestions all, got the bota finished up this afternoon. Next weekend I hope to pickup the snowblower. Some shots of the gr apart.
Sent from my SM-G900V using Tapatalk
tommyb
22
Wallingford, CT.
So, the top pic. shows the bent lever next to the new one.
You can really clean everything up once the seat pan is removed. :D
OBKubota
Oct 21, 2014
205
Ontario
It's too bad you had to go to all that work just to change a lever but it's cool to see it all apart hope everything goes well.
tommyb
22
Wallingford, CT.
Thanks OBKubota. I know, right, that's why the dealer didn't fix it...lol.
Well, I learned a little and was able to inspect and clean everything, so it wasn't that bad. Now it's better than new.
