L 4310 PTO Problems
PBohne
L4310
Jun 22, 2010
Womelsdorf, PA
I have a problem with a L4310 HST PTO. The PTO operates fine until it is put under load (60" flail cutter). Then I get a loud racheting sound. Any ideas?
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
My pto has a oneway clutch on it. It allows the bush hog to contine to spin without pushing the tractor. If yours has it, it may be bad.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
The l4310 has an overrunning clutch. It has slipped a few too many times and will need to be replaced. This is usually caused by engaging the PTO without using the foot clutch. The tractor will need to be split between the transmission and the rear end to do this repair.
Ed
PBohne
L4310
Jun 22, 2010
Womelsdorf, PA
Thanks for the information. I bought the l4310 used but it has a thirty day warranty. It is off a the dealer for repair.
Jonny4523
L4310 HST
Nov 10, 2022
30
Lafayette, IN
Here is a link to some pictures one of which is the L4310hst pto clutch.
http://work.eserv.operaunite.com/file_sharing/
070 and 060 are the parts that have rounded off to the point where they are not holding anymore.
Ed
I know this is an old post, but I'm having the exact same issue that's described here. Your link is no longer working. Any chance you could point me to a new parts diagram with what you're referring to?
N3BP
Sep 20, 2016
504
236
Lebanon, PA
Yup! It's very tempting to just engage the PTO without clutching. Especially when you’re off the machine and it's just idling. It's going to be an expensive fix thought if you're not doing the repair work yourself.
Jonny4523
L4310 HST
Nov 10, 2022
30
Lafayette, IN
Tractor is new to me. I’ve always used the clutch when shifting to different speeds or turning on the PTO. This certainly reinforces that decision.
I’m estimating $3500 repair. With three young kids, two jobs, and a night class, I just don’t have the free time to do it myself.
