Kubota L1801dt head bolt torque values and sequence
kubota L1801dt
L1801dt
Jun 3, 2015
NC
I have a Kubota L1801DT that belonged to my grandpa and I am getting it running as a kind of memorial to him and I need to know the torque specs and sequence on the head bolts.
P.S: the tractor will be seeing a lot of use, he would want it that way
8,185
Look down on the side of the tranny by the clutch pedal. Should be a plug that is painted orange. To check fluid level pull the plug. If oil runs out your good. If no oil flows out of hole then you need to add some fluid till it starts to come out that hole :D
kubota L1801dt
L1801dt
Jun 3, 2015
NC
So I have arrived at a new problem. I have replaced to blown head gasket but now I have no compression and I have no Idea why so any advice or help would be great
8,743
No compression, :confused:
#1 cause: Valves are adjusted wrong.
