Can't find Kubota stabilizer parts
coderbond
Kubota L3600
Mar 16, 2014
20
Selah, WA
Anybody know where to find these after market and affordable? The factory replacements are 250 more than a complete aftermarket kit. They're going on a Kubota L3600.
Factory Part Numbers
31351-71540, left hand
35070-71560, right hand
bh115577
2004 BX 2200, FEL, 60" MMM
Mar 5, 2015
123
39
Central NY
I believe I saw something like those in TSC last time I was there. No idea of the price or sizes though.
We have several L sires Kubatas and when we break the stabilizers they get replaced with parts from another brand tractor (green in color). Hope I don't get in trouble for that. They are cheaper and hold up better.
8,009
I was able to find the crank one at tsc. Just removed the old one and took it in and matched it up.
2,815
Are those adjustable? Hard to see in the photo......someone here can provide you with the measurements I am sure!:D:)
bh115577
Mar 5, 2015
123
39
Central NY
Not sure if this will help with the sizing but this is what I've been changing them over to when they get destroyed and both sides are adjustable.
This one is about in the center of the threaded area for adjustment and is at 19.5" from center to center of where the attaching pins would go. Pins would be 16mm or 5/8 diameter and would need to be 2.5" long to go through the clevis.
Injector in the pic is one that goes in a Kubota V2003 engine to give you an idea of the size of the setup.
The 2 clevises on the ends are $23.94 each and the entire center section is $54.85.
8,009
Looking at his pic at the top of the page, it looks like the op is looking for the piece that attaches the upper and lower lift arms for the three point hitch. Not the ones for the side to side sway. At least those are the ones circled in the pic :p
coderbond
Kubota L3600
Mar 16, 2014
20
Selah, WA
Sorry, I are dumb... not sure what the part is called.... maybe that's why I can't find one on the internet... searching the wrong term..
What the part called? :confused:
8,009
Lift rod assembly is the right hand side. Left hand side is the lift rod :D according to my parts list for the l185
