B7100 D front axle bushings
Steve NC
B7100D, L2900DT, ZD21, G6200,
Dec 29, 2014
89
Sandy Bottom North Carolina
The center pivot bushings on my B7100D front axle are pretty worn. Has anyone changed these before and have any advice on how to remove and install the new bushings? I figured this was a good time to go ahead and change these since the engine is out of the tractor for rebuilding.
8,743
Yes perfect timing, pull the pin and drive the bushings from the opposite side out.
Replace all 4 O-rings (#'s 7, 22) , 2 bushings (#6) and the pin (#21) at the same time.;)
Steve NC
Dec 29, 2014
89
Thanks Wolfman, I didn't know if I would need anything special like a press or not. The pin is out of spec and the bushings are on the edge of the wear limit. Is there supposed to be a way to grease them?
8,743
No grease they are lubed by the oil in the case, that's the reason for the O-Rings. ;)
