Safety locks for front end loader
Dieselbob
BX 2230, LA211 loader, 60â€￾ MMM, 2â€￾ wheel spacers, grille guard, gauges, bucket e
Nov 17, 2014
196
Fort Wayne IN
After going back and forth on a couple of different designs, I came up with these, which came in REALLY handy when I was working under the loader setting up my digital tachometer. I took some 1 1/4" ID galvanized pipe, ripped in lengthwise and then added nuts to bolt the two halves together and lined it with some soft rubber to protect my hydraulic cylinders. I made one for each side, and they work good and take up very little space in my tool box.
2,913
Bob ,
outstanding work ----- now when you said RIPPED......you took a cut off wheel and cut them?:D Or did you push a circular saw with a metal cutting blade? Then again, a band saw (metal cutting) would work well!! Either way, that is a great way to protect one's self in a just in case momment!!!:D:)
Dieselbob
Nov 17, 2014
196
Fort Wayne IN
I WANTED to cut them on my metal cutting bandsaw, but it would have taken quite some time to properly jig it, so I just cut them with a 4 1/2' angle grinder. You'll notice they are not perfectly straight cuts, but they fit back together as a matched set, so it's not a big deal.
ShaunBlake
B6100D; B219; Piranha bar; Hodge stabilizers; Filled Ag rears; R322T w/48" deck
Dec 21, 2014
899
Sugar Hill -- next door to Buford, GA
After going back and forth on a couple of different designs, I came up with these...
Aw, DB, you so clever! I'm gonna start a collection of yer 'designs', and start adding stuff to my stash of stuff.
I WANTED to cut them on my metal cutting bandsaw, but it would have taken quite some time to properly jig it...
I'm having trouble imagining what jig you would have had to make that would take long. What make/model bandsaw do you have? And grinding them in two must have taken a *while*! (I think I'd have gotten a 32-tpi blade for my ShopSmith bandsaw if I had to make even one of those cuts!
Dieselbob
Nov 17, 2014
196
Fort Wayne IN
My metal bandsaw (power hacksaw if you prefer) is the type where the saw slowly comes down onto the metal and is really only set up to crosscut. To rip the pipe legthwise, I would have had to figure a way to clamp it down to the saw table. Even then, I'm not sure the the saw throat would be anywhere near wide enough to cut a pipe that length. It took probably 7-8 minutes each to cut with the grinder.
2,913
DB,
A portaband would do it - much like the bandsaw - guiding it straight would be the chore - the portabands offset throat would allow you to cut.....straight would be up to the operator!:D:)
http://www.homedepot.com/p/Milwaukee-Deep-Cut-Band-Saw-AC-with-Case-6232-21/203261029?N=5yc1vZc2h4
Dieselbob
Nov 17, 2014
196
Fort Wayne IN
Between myself, my dad and my buddy, we have a LOT of tools, for wood, metal and everything in between, but we don't have one of those. I have never even used one. How in the heck do you cut a straight line with one of those?
2,913
doing what we are talking about is a tough job - need two sets of lines vertical to follow - great tool for cutting almost any situation, once the object no longer fits the throat - party over with!!!:)
great for cutting angle, square tubing, round stock, flat bar.....you name it !!! :)
8,875
Must be kubota isn't supplying safety locks for the fel's any more. Dads l2250 with la400 fel came with a set that ride inside the subframe on the left side of the tractor. Never noticed them there till I seen your post. Or are these for something else?
8,875
Makes sense. We've never removed the fel, wondered if that might be a use for them. Seem kinda thin though to support for storage
