BX25 Mechanical Thumb instalation
Timbits007
BX25
Feb 27, 2015
Toronto ,Ontario Canada
I was trying to install my mechanical thumb, on my BX25 and it looks like the bolt that attaches the mechanical arm to the backhoe arm is too big( thick) , I was thinking of filing the bracket a little so the bolt gets through.
Anybody else had the same problem?
2,869
I remember this coming up a while back - been a while!
I would not file the bracket - I would find another bolt! Either you have a metric and it calls for standard or vice-versa. Can you "measure" the hole and the bolt?
As I recall it is up there above an inch?
SLIMSHADIE
Kubota BX25D
Apr 10, 2013
445
Eureka,IL
Mine installed relatively easy, but read where others had to ream the holes out with a dremel or like to get the pin thru.
