L175 - Inherited - Newbie questions
Quebota
L175, front loader, rear scraper
Jan 14, 2015
10
Stanwood, WA
So, my father passed away several months ago and we are left with an L175 (I'm not sure of the year). I'm new to tractors but I'm trying to keep it going for as long as I can. It would come in handy to clean up my dad's property.
Anyway, I have a few questions that maybe you can help with (sorry for the length).
1st: The starter was working but it looks like it's completely fried. I took it out and jumped straight to the posts and it did nothing. My brother took it apart and he seemed to think there was some arcing/corrosion on the shaft that the brushes ride on (sorry, don't know the proper name). So I think my brother and I are pretty set on getting a new one but wondering what/where people are getting theirs. I saw this one: http://www.maniacelectricmotors.com/l185kubota.html
Does this look right and has anyone dealt with this company?
2nd: Ignition (keyed) switch. My father didn't want to pay for a new one so he bypassed it and now I'd like to get it back to original. I see two on messicks.com but not sure which one will work or what the differences are. The p/n's are: 31220-31800 and 37150-31800.
3rd: Where do I get the wire fuses for this thing? Or does someone have an alternative to upgrade the fuses to something more modern? I have a few ideas but don't have the original fuse box dimensions with me. If anyone can send me the size of the fuse screws and the center line to center line of the fuse screw dimensions I think I can come up with something. Original wire ones will do for now if I can find them.
4th: There is fluid leaking around the gear shift/pto levers. I thought I read somewhere that there might be a clogged vent in the transmission that might fix this but not sure where it's located.
5th: I have a new 750 CCA battery. I see others recommending 850 min. Do you think mine will be adequate? What size battery cables are people using?
Sorry, for so much at once. I'm just not sure where to start.
Any help is appreciated.
Darin
8,106
Welcome to the site :D
For the starter, you can always send it in through either the auto parts store, or find a local armature sevice that rebuilds starters. As far as parts numbers go, you can go to this link and download the parts manual. It's a free site and i've used them on a couple occasions. This will answer most of you questions about parts. Some of the numbers have changed, but it should tell uou when you order the part.
http://www.kubotabooks.com/AutoInde...s/&AutoIndex=c966f449fbd732b213d52b743ab323bf
And if you send me a personal message with your email address, I can send you the work shop manual for your l175.
I'm assuming your talking about the bus fuses in the dash. They are a standard size fuse which you can get at the local auto parts store or even a truck stop. the old ones should have the size listed on it, on the silver part. Should say like 7amp, or similar.
Under the seat you'll see a tube sticking out sideways that resembles a question mark. Thats the vent tube for the transmission. To get to it, you'll have to remove the tool box, and then you should have enough room to get on the pipe with a pair of pliers to remove. It's just threaded into the side of the transmission.
750cca battery should be plenty to start your tractor :D
Quebota
Jan 14, 2015
10
Stanwood, WA
Thanks for the quick response.
I will check the part numbers in your link. Thanks.
I think I already have a workshop manual and the operators manual as well. It just doesn't seem to go into a lot of detail so I like to talk to someone "in person" on forums.
Attached is a picture of the fuses I have right now. Plus some wire dad jumped across one.
So, is that vent tube on the top or side of the transmission? Is it directly under the seat? If you have a picture I'd appreciate it.
I kind of figured the battery would be fine but when we started having issues with the starter I began to question the battery.
Thanks again.
8,106
It's directly below the seat on the left side as your sitting on it. Here's a pic of the vent.
Quebota
Jan 14, 2015
10
Stanwood, WA
Thanks for the picture and the part number confirmation. I'm pretty sure that vent tube is gone from my Dad's tractor but I'll have to take another look. I assume I'll have to look at scrapped/parts tractors to find that vent tube.
Tooljunkie
May 13, 2014
4,150
The fuse panel is missing u shaped clips. The screws held them down. Regular glass fuses snap into clips.
The vent tube may be removed and plugged. Sitting on seat,it seems to me was on left side towards tool box. I had same issue,removed toolbox to access it and clean out port.leak stopped instantly.
8,106
Here's the part number for the breather tube. Part # 34260-37270, costs under 8$
Quebota
Jan 14, 2015
10
Stanwood, WA
@Tookjunkie - Thanks for the info on the fuses. That was going to be my fix. Didn't even occur to me that, that might have been the original design.
@Daren - Thanks for that part number. I was having trouble finding it in the parts manual.
Quebota
Jan 14, 2015
10
Stanwood, WA
It's not looking like the L175 (or possibly just mine) had the transmission vent. Anyone able to confirm this? If so, what should I look at next to solve my leak around the shifters.
Thanks.
Tooljunkie
May 13, 2014
4,150
Great, picture loaded 90 degrees out. Oh well i hope you get the idea.
8,106
Thanks.
Do you have a plug under the seat, either looks like a bolt or possibly a square plug.
Have you checked the fluid level in the transmission?
I went through the l175 manual and didn't find that vent. Found it on the l185 manual. It's pretty vague on the filler caps and has them listed as plugs. Looked at every parts sheet and doesn't list any vents. Wondering if that model was vented through the filler cap or through the boots for the for the transmission and pto levers.
8,106
I guess thats possible, i guess fluid level too high would cause this.but it still needs to vent somewhere.
I agree, there should be a vent. When I changed the oil on mine, it was overfilled by a couple gallons. Even with the vent cleaned out, it was still slinging oil out the shifter boots till the oil was drained down to the proper level
8,713
The L175 has a Vented cap no other vent.
If the shifters are weeping oil they probably need new O-rings installed.
Here is the cap's vent (hole on the side)
MadMax31
BX23S, 60" MMM
Nov 5, 2014
763
New York
Pic of oil leak would help. My steering box needed to be rebuilt. I learned this asfter water ran down steering shaft tube, through seal and pushed all oil out back up tube and down the outside on the gear selection area. I literaly found in the nick of time. 10 degrees out side and steering was locked right up. Hit with a torch and water came flying out of it. Opened it up and there had to be over a cup of water in the bottom. It wouldve blown out the assembly.
I fried my starter, my own fault. Ordered new on-line ~170$. I ordered an alternator, which caused dead battery, which caused starter to cook through my own stupidity....
The wire harness doesnt match, debating on cutting wires and crimping ends to retro-fit alternator....
Battery cables bit me too. New 850CCA battery and cables and she fires in seconds.
New glow plugs. Had to remove intake manifold to get at one of them, so I ordered new gasket. Threw in new air filter while I was at it. Rebuilt Tachometer "sending unit" few threads on that joy.
Still need decomp cable, tachometer cable and one headlight. But she brush-hogs fine without that jazz...
MadMax31
BX23S, 60" MMM
Nov 5, 2014
763
New York
I dont know how, but I forgot- Removing nearly the entire front end to change the V-belt. I have an electric front PTO. To remove that shaft I removed radiator, because it was plugged with dirt anyway. And while that far I replaced the upper and lower hoses. After radiator was thoroughly cleaned I finally got to re-assemble tractor. New fluids and I parked it under a tarp for the winter... It probably wont even start come spring....
