2013 bx25
Haidagwaiiderek
Skidegate
By slow reverse i mean the bx seems sluggish in reverse at any rpm in high or low range , there is no visable obstructions , oil levels are good it just has no power in reverse
8,764
Three post on the same problem? :confused:
Hit POST REPLY not new post! ;)
8,764
Three of the other posts you started all asked questions and needed more clarity.
I suggest that you look into the linkage for binding or bent or broken parts.
Could even be as simple as needing the pivot point lubed, that's about the only grease point on that tractor.
Haidagwaiiderek
Skidegate
Thanks for the info , figured out the problem there was a bolt on the rear of the linkage that was pressed into a fuel line!!! Way to close to being a major repair , if any one else has the same problem take a close look up above the hst filter where the linkage connects to the trans, it actually cut into the fuel line.
8,764
Glad you found the problem! ;)
