I recently purchased a fairly sad B7100 with a mid mounted RC60-71H deck. After using it a couple of times on some heavy grass around the creek I pulled the deck off to check it and see how much luv it needed. after some serious wok it is now ready to hook back up and start using but I cannot find any info on setting the deck height. I get the general principals but would appreciate help with things like the rear outrigger wheel heights and how much the front needs to be higher than the back. Currently the scalping wheels would let the rear of the deck hit the ground I think. Any help would be appreciated for this downunder learner
thanks
Buddha -
I am right there with you, same machine a little different deck, when i test drove the old girl yesterday, it cut fine, a little low for me, but it cut fine. I had to take the deck off to get it home. Now I want to work on the blades and grease everything before I get it back under ( which is gonna be a pain in the royal ass) have to
I will have to "look" at the linkages and whatnot, but the front guide wheels are designed to pivot and the rears have three wheel to keep it level - thus me thinking it is gonna be on the ground.
Now, I have NOT looked by I do not see how this deck is held in a floating position like my BX - someone tell me if I am wrong - ......my BX floats on a pin that stops it's downward set position. The RC60-24B deck seems to "Rest" on the ground....
AS for as front and back, keep the front lower by about 1/2 inch
looking forward to anyone's thoughts on this deck!
