Recently bought this mower. PTO shaft and coupler were rust froze.
Both issues have been fixed. There are a couple of cracked shields my son-in-law says he can weld/fix.
I can hook mower up to my B7610 3pt w/o a problem. Tractor will lift mower, albeit tilted.
I think the tilt is related to the wide vs. narrow setting, but Im not 100% sure.
Problem.... the Kubota drawbar is to high for the kickback bracket. Bracket hits PTO shaft.
I do have a drop down trailer hitch, pinned to tractor as the drawbar.
This resolves the bracket/PTO shaft issue, but now a new problem.
Once I enlarge the hole in the hitch, the chain will still be to short.
There is a bolt connecting the chain to the mower, should be an easy fix.
My question..... the trailer hitch was made by my son-in-law for a small around the yard trailer.
It's no where as beefy as the drawbar.
Would you use it? Is there a drop down drawbar?
Thanks much...notnew...
