What have you made for you tractor
Freakingstang
NE Ohio
Made a snow blade from a B5000 dozer blade for my G1900. MAde the front receiver to mount on the tractor. Made a rear hitch and weight bar for it also.
Wrong color, built the entire front end loader from scrap on the little satoh. Also made forks, hay fork and a rear hitch/suitcase weight holder. Just sold the Satoh and bought a BX2230, so more fabbing coming soon
phildac
1984 B8200E, L260F
Jul 29, 2009
203
Wentzville, MO
Made this last fall for skidding logs. Not pictured is the choker chain to keep the log low and close to the tractor.
Tooljunkie
May 13, 2014
4,150
29
Centre pocket is for ball hitch. It works great for moving trailers around my storage building, easy to line up.
Forks fit pallets well,would guess moved 500 lb pieces no problem.
kcservak
L2250 with backhoe 72" finish mower and front dirt blade.
Sep 25, 2011
61
poughkeepsie ny
some forks for the 8200.
Snow plow
weight bar
soil screener
ripper bar
future projects
3 point chipper
finish mower
Sorry,
only have the forks picture right now. No snow, so I have more time to work on projects:D
rpage83 I know this is an older post but was wondering if you could post some detailed pics of your forks it looks like a great design just what I have been looking for.
Thanks Keith.
oldenough
Arkansas
Welded two chain hooks to the bucket. Attached a chain hook to an old logging hook. I can stretch a chain between the two hooks on the bucket and hang the logging hook from the center. To move a large log I just position the bucket and tap the logging hook into the log and it will hold it enough to keep the log in the bucket. Works good when the log is too big to roll into the bucket.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
BRILLIANT I love the loggin hook idea. Does the hook turn the log loose ok when you're dropping the log?
oldenough
Arkansas
Yes, the log will drop right off when you tilt the bucket down. You don't even have to get off the tractor to drop it. If you have a helper to set the hook you don't have to get off the tractor to load it either. Just be careful with a big log and don't raise it high enough to drop it into your lap.
jay87t
B6000
Aug 4, 2013
62
Niagara Falls
Hey Mike, what control valve did you use from John Deere, I want to retro fit power steering to my b6000. From what I see, John deere control vavles have wierd connections at the control valve that are held down with some sort of plate.
I know how much we all like pictures, so I thought I would start this thread to see what out there and to get some new ideas.
My Tractor is a 1995 B7100hst 4WD.
Brush forks Made from 1 1/4 " rebar from the scrap yard cost $.22 a pound
View attachment 9814 ,
Reciever hitch I made to move trailers.
View attachment 9815 ,
Wheel weights made from bar weights from scrap yard cost 22 cents a pound. 100 pounds per wheel.
View attachment 9816 ,
Power steering made from a john deere control valve and a hydraulic cylinder from ebay. cost about $300.00 (well worth the cost)
View attachment 9817 ,
Front end loader from a bigger kubota tractor B1750, I had to rework the sub frame. Works great, and I got it cheap.
I have more but it will only let me download 5 pictures.
mike
bmwmike
B7100, 1640A loader, tiller, box blade, grader blade, carry all. John deere 455,
Jan 13, 2013
79
clarksville, Tn.
jay87t
the control valve is from a john deere 400 garden tractor from the late 1970's. The valve activates by a push , pull handle that connects to the pitman arm. the valve that I bought from Ebay came with the JD pitman arm and I just used a 1/2 " coupler and connected it to my tractor, so I did not have to cut my pitman arm , and in about 10 minutes I can make mine manual steering again if I have to.
mike
4,198
Made a simple light bar last fall for winter ops.
Took a little beatin' this summer mowing.
Lights still work, so I'm ready for raccoon season!!
Really - just a little realignment, and we're good to go!!:D
flynavy
B7100 HST-D w/FEL,654 Whel Hrs w/blade, 2654 Hsqv mowr, 28h Cfstm snowblower&cab
May 1, 2014
95
Laurel Springs, NJ
Hay BMWMIKE, thanks for the wheel weight photos, GREAT IDEA!!:)
Tooljunkie
May 13, 2014
4,150
29
Made a heavier counterweight for the front,32"x6"x3". Should be an improvement, about four times the weight of the other one. Need it for snowblower and rear forks.
coachgeo
Nov 16, 2012
2,460
32
Southern OH
No picture....... then it didn't happen:D
