ZG123S
robin416
B2401
Apr 30, 2021
17
Alabama
Don't recognize that tractor? It's because it's a Kubota zero turn gas powered.
Any way, I spun the belt. Found a chunk of grape vine in the rear pulley. Put the belt back, engaged the blades and they are still dead.
Any addicted Kubota owners have a zero turn that might know where I should check now.
BTW, I'm a 71 yr old woman so some things are going to be out of skill set. I did replace the starter solenoid a couple of years ago so I am capable of doing some repairs.
Now to go get the tractor out and put it to work.
5,506
2,213
There are a bunch of factory modifications that were supposed to be done on those. I don't know which ones it might still be eligible for and which are expired. But...if you call a dealer with your model and serial number, they can tell you.
Likely, the belt is off of one of the pulleys on the mowing deck. Or perhaps the clutch and/or wires are damaged.
robin416
B2401
Apr 30, 2021
17
Alabama
Thanks for that info. I'll contact them today.
Belt isn't off anymore. I've checked all of the other pulleys and it's in place. What I don't like the feel of is how loose the belt is at rest. So, something is not right somewhere and now I do have more serious concerns about what it is.
