My ZD21 diesel mower will not Turn over when I turn the key. I checked the seat switch and it is ok. The battery is good even under load. Can anyone give my a few suggestions before I have to take it to the dealer. Thanks in advance, Jim
I'm with you Skeets....if your dumb enough to be killed by a lawnmower without a seat safety switch it would have just been a matter of time before you found a way to be crushed by a clock radio anyway.Sad thing is they could give two hoots about your safety, it's all product liability and the lack of common sense in the consumer and taking responsibility for your own actions, and sleaze ball lawyers ! Just MHO you understand
If your starter is doing the clicking and not some relay try doing your load test with the positive lead on the battery post and the neg. lead on the frame, not the neg post. If it fails the test or falls flat you have a bad connection with your cables. If it is a relay clicking it could be a bad safety swtch as stated above.My ZD21 diesel mower will not Turn over when I turn the key. I checked the seat switch and it is ok. The battery is good even under load. Can anyone give my a few suggestions before I have to take it to the dealer. Thanks in advance, Jim
