ZD1211 Fuel Tank issue
texaskubota
ZD1211
Feb 28, 2023
41
This has been an ongoing issue. The right tank is almost always full. I've made it a habit to just siphon fuel out to finish a mow. I finally undid the right tanks fuel filter to confirm there was flow. There is. Outlet side of the filter also shows flow.
Today with low fuel in both tanks, (but enough) I had to mow some inclines etc. it wanted to stall when sideways (right tank higher). Which is puzzling.
I'm not sure what to think. Possibly time to change the fuel filter(s)? It's still not at the replacement hours interval last i checked.
11,138
If flow is good out of both tanks all the way to the lift pump it could be a failure of the lift pump?
