Z724x not starting need help!
jlklos
Springfield
I have a Kubota z724x wont start not getting gas to the filter put on new filter and fuel pump still not getting gas to the filter line is not clogged what should I check next this mower has only 56 hours 2 yrs old like new? Would take to dealer but they closed!:confused:
1,874
There may be other filters before the one you found. You can try to blow air back through the lines towards the gas tank and see if fuel will flow then. Be sure to take the cap off the tank first and put some rag over the filler inlet to keep from blowing gas all over.
If fuel flows then you have stuff in the tank blocking the fuel flow and will need to clean the tank out
5,426
2,122
There is a fuel valve at the back/center of the fuel tank. The valve makes a hard 90 deg turn from the fuel line down into the tank grommet. Common for dirt to get inside the fuel tank and plug the valve and/or it's pick up tube. Just pull it out and blow it out from the engine side with compressed air. This should free up any dirt that might be inside. I like to catch the junk that comes out in a bag or something so I know what was in it.
