Z421 needs to be towed out of backyard for repair
lisarich
Kubota Z421
Sep 12, 2022
Cary, NC
Our Z421 made a clunking sound and now can only mow, not move forward or backwards. We called for Kubota service who will take it away from our driveway only but we need to get it out of the backyard up a slope to the driveway.
If I am reading the manual correctly, we need to disengage the Hydrostatic transaxle bypass rods (or set them such that the transmission is disengaged) and we should pull it with a truck or something with no one behind it should it break free.
Is this correct?
Thanks for any guidance.
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Titan Forks, Caryall, 5' Tiller
Oct 26, 2019
234
424
Moseley, VA
Probably just the drive belt. Not too hard if you have a few tools. I have to replace the one on my Husqvarna PTZ about every two years.
5,409
2,104
z421 belts are no fun
there was a bulletin that addressed it ask the dealer if yours applies or if that bulletin is even still active
CharlieLH2
Z421
Aug 20, 2023
Cleveland, Georgia
Drive belt most likely. My mower did same thing with about 350 hours, clunk and no forward or rear drive. Wife and I replaced drive belt, not to hard.
1,774
Is this correct?
I have no idea how you would disconnect the hydrostatic drive but once they are inactive the mower will be able to freewheel down hill so just don’t let it get loose or stay out of harms way.
If you pull it just go slow to avoid damage to the drive system
Ktrim
B2400, lA352 loader,3pth quick hitch/z122r zero turn/restored 52 farmall super a
Dec 23, 2020
444
369
Nazareth Pa
I know on my 122 the left side rod drops into a slot further back but the right side rod has to be held back while the machine is moved. Not sure why kubota made it like that.
whitetiger
Nov 20, 2011
3,092
1,526
Kansas City, KS
It was made that way as a safety. You have to manually hold the rod in neutral for the unit to roll. If or let go of the rod, it moves back into its home position and the unit stops rolling.
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Makes it hard to move if you're by yourself. Drill a hole for rod to drop into and problem solved
