I have a Z421 zero turn. The fan on top of the HST pulley broke. I’ve purchased a new one but can’t seem to get the old pulley off. Is it just the nut or do I need a pulley puller? What can I hold the pulley with to keep it from spinning?
use impact wrench, zip the nut off. Then yank the pulley off by hand. It just sits on it's hub. The hub can occasionally be a bear to get off but not all that often.
there is a bulletin out for the z4xx series that addresses frequent belt throwing, and if you have experienced it, it would be wise to have the dealer address it if it's still got any warranty on it. They are installing wider/deeper hst pulleys, tensioner is a little different, and some other stuff. It is an impressive kit.
for those that want to change their own pulley the LH one is easy, get right to it from aside the fuel tank. The RH one, you will be inventing new words. Remove the HST. There's another way, which I won't get into, it's a pain in the back side and it's just easier to remove the HST.
