Work Light Switch B2650
normd
Waynesboro, VA
I understand I can install a work light switch in the cutout next to the regular light switch on the dash. I even have a part number TD350-75360. However, I am unsure what connector/outlet/circuit this switch will control. My understanding is the connector under the rear fender is hot whenever the ignition switch is on, so where is the connector/wiring that the work light switch controls?
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
342
282
Bigfork Minnesota
On a cab version of the B2650, the switch and wiring control the rear work lights that would be just below the roof line. The plug is already wired in on the same side as the unused cutout, and just taped to a support under the dash until used. If you are referring to an open station B2650, maybe someone with on will chime in. But my guess would be that it would be terminated somewhere near the rops so the rear work lights could be connected to it there.
i7win7
Feb 21, 2020
3,377
3,992
Central, IL
I prefer to add my own electrical system, keep factory wiring - factory original to avoid warranty issues.
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
401
66
Wa
On the B2650HSDC this would be all factory wiring.
If you buy their kit, then you get everything you need.
If not, then the only issue is finding the matching connection to the factory plug for the lights themselves.
The wiring harness is all factory installed, just needs the switch and lights.
i7win7
Feb 21, 2020
3,377
3,992
Central, IL
Depends on how "hog wild" you get with electrical accessories
