Wood Chipper max/min for L4701?
Jbillow
L4701
Mar 3, 2022
North Plains, OR
I’ve gotten to analysis paralysis… Too many options….
I have a L4701, and looking at a 4” Titan BX42S Chippper.
Does anyone see any issue with that? It say it’s rated to 40hp, and the PTO HP on the tractor is 37.8, so it seems like it’s about right….?
Of course, I’d like to be able to chip the largest size I can on my tractor, but seems like if I go with bigger diameter chipper I may not be able to get there anyway with the PTO HP?
Thanks in advance!
UpNorthMI
May 12, 2020
849
566
Up North, MI
I run a WoodMaxx MX 9900 on my L3901, the chipper is a beast and feeds 9”.
As you analyze I suggest you look at how much you plan to use your chipper and what is your budget.
WoodMaxx use 2 hydraulic infeed rollers on many of their models, this is far superior to one driven infeed roller.
you have plenty of PTO HP to run a bigger chipper than 4”
Good luck making a selection.
animals45
L3301l
Apr 22, 2021
282
Mabie CA
I bought a stand alone chipper/shreader @ 35 years ago & i was looking at one that did 4" wood & then I got to thinking about it & 4" wood is still fire wood around here
animal
5,137
I have a Woodland Mills WC68 which is rated at 6” capacity when paired with a 38 PTO HP tractor per their website https://woodlandmills.com/product/w...EgaICR0QWghpEAAYASABEgIndvD_BwE#compatibility. The L4701 is rated 39.3 PTO HP, DT /37.8 PTO HP, HST. In my experience, my chipper will chip 6” without bogging the motor. Assuming the chippers are of similar efficiency the tractor should have the power to chip around 6”. With a 10’ white oak stick about 4” on one end and about 6” on the other end it’s grunting hard but it does it without stopping the feed to let the engine catch up. Doubt it would do much more and that’s all the chipper will take regardless. Stuff that big is usually firewood for me anyway unless it’s pine or sweet gum.
I prefer the hydraulic feed chippers. Some don’t care about that. I’ve run double drum hydraulic, single drum hydraulic, self feed with the angled chute, and the old style throw it from 6’ away and it zips through about 100mph. Hydraulic feed is just my personal preference partly because I can slow the feed rate to avoid discharge chute plugging with sappy pine and sappy eastern red cedar, and speed it back up for dry stuff or hardwood.
So far as the specific model you mention, I take it this is what your looking at: https://www.palletforks.com/tractor...oint-wood-chipper-attachments/WCBX-GROUP.html
If yes, you might want to check out this thread. I’m aware it’s got some age on it but it appears the OP, @sdk1968, is still around so he might be able to give you the long term review on it.
5,773
I've always considered anything bigger than 4" to be firewood, either to heat house or campfires seems a shame to just 'mulch it up'. :(
Friend ran an 8" chipper off my D-14 one long,log weekend,that was 3-4 years ago, so I forget the make( 'red' though...)
RalphVa
738
321
Charlottesville
Thanks in advance!
You can chip WAY bigger than 4 inch on your tractor. Hp goes up by square root of hp; so, I'll bet you can chip 16 inch on your tractor. Don't think you can get a PTO unit that big.
My 4010 at 18.5 hp chipped up to 3.5 inches on a MacKissic TPH-122 for 9 years. Used it on the 24.5 hp 1025R and 2025R and was using a WC46 (4 inch by 6 inch) on the 2025R, and it was just loafing along at 450 rpm PTO speed. Got the WC46 on the B2601, and it, of course, just loafs along at about 450 rpm PTO speed.
Old_Paint
Dec 5, 2020
1,890
2,031
AL
Thanks in advance!
That rating means it will handle UP TO 40 HP.
I have the Woodland Mills WC-68, a 6 inch chipper, on a little LX2610SU, 19HP at the PTO. The WC-68 is rated 40 HP too, but if you'll look at the specs, you'll find it doesn't really say what a minimum HP is. The WC-68 doesn't miss a beat, and it takes at least a 5" chunk to bother that LX. You'll be fine with a 4", but I'd encourage something much larger with that L, if not the largest one you can find for a 3 point hitch. It's the mass/speed of the flywheel that counts most. Higher speed units (usually belt drive) typically have two knives, and lower speed (usually direct drive) typically have 4 knives. This pretty well keeps the number of cuts per minute about the same because the high speed units normally run about 1000 RPM, and low speed ones are rated for 540 RPM. Higher speed units typically have a lighter flywheel because higher speed and lower mass can produce as much cutting energy as a lower speed and higher mass. If you want 5 only ways to do something, just ask 5 engineers, but it's pretty simple math, really. A larger opening will let you handle crazier brush than the 4" without having to trim and cut to straighten it up so much. If you get something that small, you're going to have to do a lot more 'prep' work to be able to feed the brush into that chipper, especially anything over about 1 inch in diameter. ABOVE ALL, get one with hydraulic infeed. I have a little 3" Briggs powered chipper/shredder, and plenty experience of how much that thing will hurt you with all the vibration transmitted through the material. You will do a lot of nerve damage in your hands and wrists with a manually fed chipper.
You'll typically run out of chipper long before you run out of tractor. Most of all, BE SAFE and read about all the hazards you're buying into. Chippers are VERY dangerous beasts.
charger68
L3901 HST, WM-8H, RCR1860, SCG1560, GS1572, HD25
May 18, 2021
10
20
Milledgeville, GA
We have the Woodmaxx WM-8H on our L3901 that can handle up to 8" material. We choose not to go that big with what we chip, but the larger infeed and reversible drive of the hydraulic unit really makes the unit amazing.
I can not overstress how important it is have the ability to reverse the infeed drive. Makes clearing jams a breeze. We have been clearing all of the underbrush and vines from our property and this unit has been a tremendous help in that endeavor.
RalphVa
738
321
Charlottesville
We take both a ratchet drive with 24 mm socket to open up the top and a low rise floor jack to raise the roller on the WC46. Had to use the floor jack one time this afternoon but had no plugs of the discharge chute because we were chipping mostly all woody stuff and not much greenery.
Of course, had to reverse the roller a number of times when the roller was chewing on a crotch. Just turn and put roller feed back usually works.
hope to float
L3450
Feb 18, 2018
485
61
Ireland
!00% agree on getting one with a bigger opening. Otherwise you will have to cut every kink and Y out of every branch.
