won't start when hot
Timberbank
MX5000
Aug 22, 2017
11
Stouffville
I have a 2007 Kubota MX5000 which turns over and starts fine cold. Once at operating temperatures, if I turn it off, it will not re-start. It won't turn over, nothing. I checked all safety switches, let it stand for 10 minutes, put gear selector and range selector in neutral and it starts. I have re-started it in gear, clutch depressed and range selector in neutral. I have re-started it with everything in neutral and with me off the tractor. This has happened the last three times that I used the tractor. The last time I pulled what I think is a relay plug in on the starter wire and it started. Any advice? Thank you in advance, Frank.
8,605
Usually hot start issues can be attributed to a bad starter relay or bad stop solenoid relay.
BR25004X4
Kubota B6000 L3901
May 12, 2017
41
Columbus, NE
Have the battery checked for a short that only happens once the battery is warmed up. Happened to my dad with a pickup truck he had in the late 70's. Had about the same symptons.
