wiring issues
Diesel
sarnia
Hello, my HST 5200 diesel has been sitting for a while. I went to start it and just turns over and over. The power seems to be going to the starter but no where else, no power to glow plugs, fuel pump etc.,
I thought maybe the ignition switch was bad? Didn't think kubota was know for bad ignition switches. What's the best way to check it ?
Inline fuse seems okay, checked grounds, wires seem all hooked up okay ??????
Any ideas, let me know, Thanks
8,678
A muti-meter or a test light will work.
If it's cranking then power is getting to some of it.
Do you have a manual for it?
It will be easier and faster if you can get a wiring schematic for it.
Test to see if your getting power to the fuses first.
fytnfyr
Kubota BX2200 with Snow Blower
Jan 4, 2014
Lake Tahoe, California, USA
I had a similar problem and it turned out to be the battery. Mine had enough juice to start the tractor, but not enough voltage to keep it running. I charged the battery and the issue was fixed.
It's worth a shot since it's a cheap and easy fix.
Good Luck,
Mags
