Wiring diagram question
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
In the wiring diagrams, the wires are identified in this format: "AV 0.5 Red"
What does "AV" stand for, and what does the number such as "0.5" mean? Is the number some sort of wire size designation?
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
A = Automotive type wire
V = vinyl insulation
0.5 = size-----I don't think it is a direct mm measurement but close
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
That makes sense, but I do agree it can't be mm. For instance, the starter hot cable is labeled as "20", but it's obviously not 20mm in diameter.
Stumpy
L175
Dec 1, 2011
848
NE Ohio
A wire's current carrying capacity is determined largely by it's cross sectional area. In the metric wire gauge system sizes are referred to by their cross sectional area, so AV 0.5 is an automotive grade vinyl coated wire as Sam said and has a cross section of roughly 0.5 mm^2. In the American Wire Gauge system the AWG number is just an arbitrary reference to the different cross section area sizes. Both systems assume a solid wire so stranded wire will always be a little larger in actual diameter than the value in the table.
Here's a conversion chart. http://www.rbeelectronics.com/wtable.htm
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
Good info Stumpy. Makes total sense. When I got my new residential service line they spec those cables by cross sectional area as well but use circular mils.
