Winterizing fuel...maybe a little late
skinnypez
B2650
Jun 23, 2018
Missouri
Hey all.
Colder nights snuck up on our area a little early this year and my B2650 is the only piece of diesel equipment I've ever owned, so I wasn't really thinking about the impacts on the tractor.
I didn't get any fuel treatment added and it's been down to about 15F or so a couple of nights. Tank was filled a couple of weeks ago and is probably 80% full- do you think I've caused an issue by not treating it already?
Thanks.
SidecarFlip
Banned
557
Probably not if the added fuel was fresh. It needs to get below 0 before I add any additives.
WFM
L3800
Apr 5, 2013
1,476
891
Porter Maine
I'm no expert. But I think you'll be fine. I just bought some Power Boost (or whatever its called) when I was in the parts store today. Get some and dump a couple ounces into your tank.
twomany
B7200
Jul 10, 2017
793
138
Vermont
If you are worried, just wait until it warms up again.
Neither tractors nor fuel have any memories of how chilly it was "yesterday".
I did dose the full fuel tanks on both oil burner tractors with Power Service yesterday. An once of prevention and all that.
The two 5 gal jugs are needing refilled now. I'm assuming 'winter blend' is at the pumps ...
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
Columbia, CT
I'm new to diesel - what is "winter blend"?
2,832
copied and pasted:
Diesel fuel comes in two blends: summer and winter. ... Summer blend diesel, also called #2 ULSD, will cloud and gel at higher temperatures than winter blend #2 ULSD, which is a mixture of #2 ULSD and #1 diesel/kerosene. It is the kerosene that lowers the gel point in winter blend diesel..
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
https://shop.advanceautoparts.com/p/diesel-911-32-fl-oz-8025-12/7080116-P
That stuff works pretty good in gel'd up diesel situations. They also make an additive to prevent geling, in a white container.
Up here, they start winter blend at the pumps in early November usually. Most stations claim it to be good to -10F.
Otherwise, put a space heater or salomandor/torpedo heater near the machine (in a safe manner of course), for a few hours, and let it warm up some before you give it a go.
In extreme situations, we've lit whole bags of charcoal under Dozers and Excavators that get left out in the elements. It works.
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
Hey all.
Thanks.
The short answer is that you are fine. I would add a winter additive now though. I use Power Service winter additive, which can be added to untreated summer diesel when temps are above 0 deg f. That’s per Power Service.... with the Cold Filter Plugging Point (CFPP) of about the same temp (0 deg f) I would want it added a little earlier!
Michigankubota
B2650 Loader,LX 2980-64 Blower ,60”MMM , Land Pride 60”Box Blade.
Oct 17, 2018
246
14
Bessemer, Western U.P.
Around here in the U.P. They sell both number 1 and 2 fuels. Plus blended fuels. I just picked up number 1 now that we are in the 10-20 degree lows. The book states you can use either fuel.
JeepinMaxx
Mar 27, 2018
296
Columbia, CT
Anyone use Howe's Diesel Treat? The previous owner of my BX used it all year round, so I've continued to do the same
Stmar
B2650HSDC
May 23, 2017
932
Buffalo, Wyoming
Like another poster said just put a few ounces of Power Service White or similar in your existing fuel tank. Our co-op has only #1 and the gas stations have gone to a winter blend. Even with the #1 I still put additive in since I don't use the tractor that much and want to make sure it is over protected.
Frostbitten
2019 BX2380
Jul 19, 2012
50
Grand Haven, Mi USA
howes diesel treatment
2oz per gallon all year 'round here in michigan
less than 10 bucks for the jug on amazon, and its a prime item
order 2, 3 or 4 jugs....add 2oz per gallon and never have to worry
